Any words of wisdom from those that have used a static V (Non insulated)
Looking to buy one from over the pond - good enough for spring summer use?
Klymit static V
Re: Klymit static V
Uninsulated (R 0.23) and 514g. Apart from the extra width I can't see why you would. Any reason why the Static V?
Think I'd buy one of the new NeoAir Venture mats instead, it has a level of insulation (R 1.8), weighs 590g and can be had for under £50: http://www.gooutdoors.co.uk/therm-a-res ... at-p292551
Re: Klymit static V
£30 & being hand delivered to me by a friend who lives in the states is what caught my eye in addition to the pack size & width
Re: Klymit static V
In that case I realy can't fault it£30 & being hand delivered to me by a friend who lives in the states is what caught my eye in addition to the pack size & width
For spring/summer it should be fine ... it does have a slightly higher R value than nothing which might be something to do with the body mapping layout.
Re: Klymit static V
It's also very tough and packs down small, which could be key features if you want it for a long trip.
I haven't used mine in anger yet outside. On the kitchen floor and in a friends spare room, it seems comfy enough. Certainly comfort than my old Thermarest. If anything, a little bit firm in the centre but I'm sure that can be adjusted with a tweak in pressure.
I am a little concerned how it does in cooler months tho....
Having said that, the Venture does look interesting. Same toughness of fabric and possibly similar pack size (and weight)?
