My P7 has sliding drop outs so I can go for proper single speed and not need a tensioner. I'm going to go with the superstar sprocket and spacers as per Stu's suggestion as it's cheap and I'm sure will do the job nicely.
So question about ratios. I'm going to be using this mostly as my commuter but still want the off road option.
I happen to have a new 36 tooth chain ring laying around and thought that maybe a 16 tooth rear might be about right? Then I could get a 32 chain ring and 20 rear to slap on if I know I want to go off road. Alternatively I could go dingle speed with these same ratios as chain length should be right. Added bonus of not needing new chain ring bolts either.
Roughly what sort of sprocket size difference in chain length does a sliding drop out cater for? So if for instance I wanted to swap from a 20 to 18 will I get away with not having to shorten the chain, just moving the drop out?
Hmm just thought, I have never moved the drop outs in 3.5 years of having the frame. I wonder if the bolts are going to move?
