Dynamo/light cable routing
composite
Post by composite »
I was just wondering where you have placed your cable guides and/or what your cable routing is like on your dynamo hub setups?
ianfitz
Re: Dynamo/light cable routing
Post by ianfitz »
i went up the right fork leg, across the stantion then up the front brake cable to the bars. used large zip ties on the forks then small ones on the cable.
i also have a bik with rigid forks and with this i just went up the right fork leg and to the bars.
Taylor
Post by Taylor »
R/H fork leg, cable tie to leg and side of brace then straight up to the bar.
Does this mean you'll be riding your new bike next week?
Taylor
Post by Taylor »
Nope, Olly's not that fast. :wink:
Last update was,
flatfishy wrote:Nope, Olly's not that fast. :wink:
Last update was,
That looks lovely - are those holes in the top tube for internal cable routing?
Mart
Post by Mart »
2 wires from the hub cableties to the RHS leg. First Cable goes up head tube, feeding into the Plug 11
Second goes to the light, on outside via stem
Taylor
Post by Taylor »
Last update was,
Yup, three brass tubes inside the top tube.
mtbmarkymark
Post by mtbmarkymark »
Up RH fork leg then to side of head tube for me
I've used bands of old inner tube on my rigid forks.
using these instead of zipties allows me to remove the wire when i put the non dynamo front wheel in
Currently using electrical tape but have some double sided velcro I'll be using next time it has a good clean.
Brothersmith
Post by Brothersmith »
johnnystorm wrote:Currently using electrical tape but have some double sided velcro I'll be using next time it has a good clean.
That sounds interesting, especially as I don't plan on my dynamo being a permeant fixture. Will the velcro not attract the cack though?
The stuff I've got is like a wider version of the velcro you get with Mucky Nuts bender fenders. I.e. its not that rough/furry but still grippy. I reasoned that with either zipties or tape you'll still always get crevices that collect cack. At least this way I can remove/reattach easily. Also, if I swap wheels and don't need the dyno I can remove everything easily.
Brothersmith
Can you let me know where you got it from Johnny?
Yeah, nothing special, just a strip from ebay. Could be a better deal out there. I give up searching all the combinations after a while!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1315850065
numplumz
Post by numplumz »
Try some Velcro cables ties, the ones with the hole in to thread through are especially strong. I use them to Hold stuff on like tubes and pumps, they are brilliant and re-usable for cables.
http://www.ebay.co.uk/itm/like/18061324 ... 108&ff19=0
