Hole my tent needs fixing. About 1x2mm big.
Is it just a case of cutting a patch out and sticking it on?
How big a patch and inside/outside?
Idiots Guide for Tent Repairs?
Re: Idiots Guide for Tent Repairs?
1/ Cut a piece of Silnylon that'll overlap the tear by about half inch.
2/ Glue it over the tear on the inside using SilNet and leave overnight to dry.
3/ Neatly mask the tear on the outside and apply a layer of SilNet directly over the tear.
4/ Job done
OR: http://www.amazon.co.uk/Gear-Aid-Sil-Si ... B003TP2NWQ
4/ Job done
Alternatively, tear off a square of gaffa tape and stick over hole. Do same on inside. Congratulate yourself with a beer. Keep congratulating yourself until you're so drunk, a bit of dampness doesn't matter anymore.
You Tube:
Thinking, "I'll fix that properly when I get back" and then just leave it.Dan_K wrote:Alternatively, tear off a square of gaffa tape and stick over hole. Do same on inside. Congratulate yourself with a beer. Keep congratulating yourself until you're so drunk, a bit of dampness doesn't matter anymore.
/pats 1998 Quasar
