back to news and reviews
Posted by
A while ago I posted something about cooking without a cooker but if you’re really wanting to push things, could you go further? Maybe there’s a way you could dispense with the pot / mug altogether and replace it with something much lighter, infinitely cheaper and available pretty much everywhere … the humble plastic bottle, that’s right I did say plastic.
I’ve chosen the thinnest, poorest quality one I could find. It’s not special, it once contained spring water from somewhere or other like countless bottles on the shelves or in the bin … something a little more substantial will obviously last longer, maybe even a couple of days use. Have a rummage through the bins and see what you can find.
The first thing you’ll need to do is light yourself a little fire. It doesn’t have to be worthy of Guy Fawkes, just enough room for your bottle to be placed in the middle. It should be noted that I don’t generally ‘go in’ for open fires but in this case (a) I’m the land owner (b) the fire is set on a shingle river bed and (c) you could just as easily use a wood stove or even a meths burner.
You’ll be needing one of these.
When you’ve got a reasonable amount of hot embers, scrape a hollow in them and place your bottle in it. Remember to remove the lid first and only fill it 3/4 full to allow a little expansion (water) and contraction (bottle) room.
Oi – take the lid off first.
Add a bit more fuel to your fire concentrating around the outside of the bottle. Don’t go mad, you do need some flames but you’re not trying to re-make the Towering Inferno.
Pop the bottle on and put a put a bit more wood ont’ fire.
Sit back and relax. You’ll obviously need to keep feeding your fire but within a few minutes you’ll have lovely boiling water.
Hard to see but the water is boiling here.
If you’re going for the full dirt-bag approach just empty your favoured powered beverage straight into the bottle and give it a little shake.
Not pretty but enough life left for the mornings brew.
Although not exactly unscathed by the ordeal, your bottle will still hold water and should be capable of a couple more ‘burns’.
3 Comments
  1. I questioned if it was a good idea to heat plastic on a fire then drink the water as I recalled a scare about cancer and plastic water bottles a few years back.
    Advice seems to be look for plastics numbered #2, #4, or #5, and maybe #1 only for one time use. #1 is the most popular for disposable water.
    Note that we've all been drinking boiling hot tea from styrofoam cups for years without thinking about it. It's plastic is #6 and on the no-no list.
    More info here http://www.breastcancer.org/risk/factors/plastic
  2. Thanks for sharing that CC, very useful.
Comments are closed.
You may also be interested in
Read Full Article
Read Full Article
Read Full Article
Shopping cart0
Continue shopping
Privacy Overview
