wrong time of year I know.
I have a set of old smart twin halogen lights with 10w spot and 2.5w flood beams. They run off a battery pack which sits in the bottle cage there is also an inline switch. bar mounts are for standard bars not oversized.
I still have the box for these!
Battery could probably do with replacing. It holds charge fine and runs for around 2 hours (from memory). I have used these for commuting over the last 5 or 6 years. There is sometimes a loose connection with it and you need to wiggle it sometimes. Once it warms up it seems to work fine.
probably best suited to commuting. good solid cheap watertight set.
looking for £10
can bring to WRT.
PM if interested.
Smart twin halogen lights
