WTD: Lightweight inflatable sleeping mat
rowlandpg
Post by rowlandpg »
Was about to order an Exped HyperLite, but I thought I'd check if any of you have something similar knocking about which you want to get rid of.
I am 5'11" so looking for a medium size in most brands
Re: WTD: Lightweight inflatable sleeping mat
Can't help with a cast off but I'm the same height as you and I've the Exped Winterlite - I got the standard M version but you can feel "perched" on it especially if you fully inflate it so consider the MW as you get a bit more room.
rowlandpg
Post by rowlandpg »
whitestone wrote:Can't help with a cast off but I'm the same height as you and I've the Exped Winterlite - I got the standard M version but you can feel "perched" on it especially if you fully inflate it so consider the MW as you get a bit more room.
Thanks for the tip!
