Pro 2 evo bearings
Taylor
Pro 2 evo bearings
Post by Taylor »
My rear hub needs a full set of bearings as its rough as a dog at the moment.
Where can I get a full set for a sensible price?
£36 seems quite steep for 5 bearings.
Re: Pro 2 evo bearings
Check out eBay for them. They are standard size bearings, the code for which is on the seal - it'll say something like 7005 2rs. The 7005 is the size and the 2rs is double sealed ( as in both sides, not each side is double sealed)
Depending on supplier you should pay £2 each for cheapies or £8 each for stainless or skf.
I use cheap ones bought in a pack of 10 and change when necessary. They rarely fail 4 at a time, so just replace the outer ones that are knackered.
Mike
Post by Mike »
I just got some INA ones from my local bearing suppler mate for mine think I paid 6\7£ each
paramart
Post by paramart »
just got 2prs from wych bearings paid a bit dearer buy cheap buy twice, usually grease up the cheapo,s but they seem to die rapid at the moment, so giving the dearer one,s a go paid £5-8 each
Matt
Post by Matt »
Just did mine with a set off ebay, turned up next day and were spot on
Have sent the link
Taylor
Post by Taylor »
Ta, pressed go about 3-4 minutes before you sent the link.
£24.70 stainless, delivered.
