What 1 person shelter?
Clink
Post by Clink »
I've used various tents before (Blacks Octane 1 and 2) for mountain marathons and occasionally used a tarp and Alpkit bivi. However I fancy a new shelter for the WRT. I prefer the idea of a more tent-like tarp, so the Trekkertent Stealth caught my eye on here. It will predominantly used in summer, but possibly at any time. Anything else similar I should look at?
Taylor
Re: What 1 person shelter?
Post by Taylor »
Lunar Solo
Giacomo
Post by Giacomo »
I've recently been pondering the same. I went for a trekkertent stealth 1. It hasn't arrived yet, but I've only heard good things...
Clink
Post by Clink »
Hi Taylor. Lunar Solo currently not available - better than the Stealth?
gairym
Post by gairym »
I'm a massive fan of my SMD 'Skyscape Scout'.
Spacey, light and not overly expensive.
Taylor
Post by Taylor »
Best ask Stu as he's used both.
They're quite different really. The Stealth scores on having a fully removable inner and an outer that can be pitched high or low, so it's very versitile. The Lunar wins on head room, porch space (just) and only requiring a single pole. I've not suffered much condensation with either but if conditions were right then the Lunar should be worse given it's a single skin / hybrid / tarptent.
Sorry, that's probably not much help.
Clink
Post by Clink »
Thanks Stu.
SMD Wild Oasis?
Richen987
Post by Richen987 »
Hi, interesting looking options,
looking at the Stealth 1, are there any major advantages over a tarp other than the detachable inner?
also would the 70cm & 110cm poles from the shop fit the bill for pitching or is it a custom pole job?
thanks for the help.
That depends how good you are with a tarp :wink: . It's easy to get a tarp set up so it looks great but in reality it's only a gust away from falling over, the Stealth is very stable.
Yeah, they'll work fine. However, if I know they're for a Stealth I reduce the rear pole to 66cm.
Matt
Post by Matt »
If I buy a Stealth I assume shortening existing poles involves copious amounts of PPE and a hack saw?
No need Matt, It will work just fine with your existing 110cm + 70cm poles.
Scattamah
Post by Scattamah »
Zpacks Solplex, Hexamid Solo or Altaplex.
No love for the solomid or duomid?
From the MLD stable, I prefer the Trailstar.
I'm playing about with a SMD Gatewood cape at the moment, similar to Nigels suggestion of a Wild Oasis but without the perimeter netting.
Richen987
Post by Richen987 »
Thanks for the reply Stu, definitely one to put on the list then.
Cheers.
Clink
Post by Clink »
I'm still favouring the Stealth, not least as it's a UK firm. Is it worth paying/waiting for cuban fibre?
The Stealth's cracking and Marc's great, he's also very willing to adjust/alter/incorporate different ideas should you have any. As for the cuben, it's certainly lighter but it doesn't packdown as small as sil' does. I suppose it really comes down to cost and whether saving the weight is worth the price.
burty
Post by burty »
i went with the trekker tent ,I got a good deal on a cuben fibre stealth with mesh inner ,
I think it should be here in the next couple of days so i am told
Richen987
Post by Richen987 »
Sorry for all the questions, but what's the real world difference between 30d and 40d silnylon?
Matt
Post by Matt »
10
Richen987
Post by Richen987 »
So not worth 15 extra then? :wink:
Matt's right, it is 10 :wink: In reality the 40d should be a bit more robust but I think unless you're using it in some horrific conditions on a regular basis the standard 30d is more than up to the job ... unless you don't like grey obviously.
Richen987
Post by Richen987 »
excellent, grey it is then, ordered, hopefully will turn up before the WRT.
Stu, you mentioned that if you knew the poles were for a stealth you would make the rear pole shorter, do I just order the poles and make a note in the requirements that it is for a stealth 1 ?
thanks for all the replies, much appreciated.
