Tubeless 29" Road Tyre recommendations
greenmug
Post by greenmug »
I'm after a tyre to use on a 29er wheel that I can put onto a bike for when I need to do road only miles (commute to work). Tubeless and fairly tough would be good.
Any recommendations?
Re: Tubeless 29" Road Tyre recommendations
specialized fast trak. works off road very well, fast on road.
mattpage
Post by mattpage »
Schwalbe Kozak is a great 29er road tyre. Not sure if its tubeless specific, but I am sure it will work so long as you don't go crazy with the pressures.
VeganGraham
Location: The sun dappled leafy glades of Worcestershire
Post by VeganGraham »
Geak Barro race for £15
I've used them tubeless on Stan's rims and they're very much a road biased MTB tyre.
Worcestershire's fastest veteran vegan mountain bike endurance racer with a beard.
ianfitz
Post by ianfitz »
You'll most likely get a 28mm road slick on. So long as your rims aren't super wide, the Planet X own brand ones seem good value.
Not tubeless but will be much quicker
After Stu's recommendations I fitted some of the On One Gravel Road tyres to my Fargo for commuting £15 each, 40c, 120tpi and enough tread to help but not so much to hinder.
greenmug
Post by greenmug »
Some good suggestions. Thanks very much all.
