A Q that will help me piece together a DIY USB system..
I can charge a battery pack from the hub output passing through a rectifier. Apparently the battery pack has a max charge rate of 500mah from the hub but apparently a 'booster cap' could raise that - I guess that's a capacitor of sorts? What spec would I need? Happy to solder it up w/o one but a faster charge would be useful.
And does anyone know roughly what charge a 7.2V battery pack (6xAA Ni-Mh rechargeables with 2500-2800mah capacity, outputting through a 5V/600mah regulator) would put into a Garmin 800? Interested in the workings too, I really should know how to figure that out.
More to follow, if I get this working I'll post it up with credit to the originator of the wiring diagram.
DIY dynamo to battery-backed USB charger - electronics Q
Re: DIY dynamo to battery-backed USB charger - electronics Q
Garmin 800 has a 1Ah battery so you'll have 6 charges or so from your AA pack. 600mAh is the similar to a boggo USB charger for speed of charging.
Thanks. More than I thought .. just trying to estimate how the timing of charging the pack would work compared to Garmin battery life, seems promising. Batteries are actually 2400mah so maybe a bit less that 6, but enough. How do you work that out?
I think the whole system will end up running at around 500ma so will get it wired up as is.
Duh. 2400mAh batteries (allowing for inefficiencies) should do your edge twice so err 12 times then?
Ok, so 2.4Ah battery = 1Ah Garmin charged just over 2x. And I have 6 of them. Could take a bit of pedaling to charge that AA pack but won't need much of the actual capacity that can be stored.
Simple .. I knew it would look like a daft Q once I understood it : )
Seems I'll get 2.4x Garmin charge max after all. 12x did seem a bit too good from one charge.. 6 x 1.2v cells in series give the 7.2V (ie a bit over 5V which I need, 5 cells should do it) needed for USB output, but only the same Ah as 1 cell. Parallel battery wiring would give 6 x 2.4Ah, but the same V ie only 1 x 1.2V.
http://batteryuniversity.com/learn/arti ... igurations
