One of the nicest sprockets I've seen ... features thick/thin teeth to help keep your poorly adjusted or worn chain in place. £29 seems like a fair price too when you consider the work in them.
Thick-thin on a SS cog, 10 or 11spd chains? no 17 or 19? I'm lost .. : )
Just use a non-geared SS chain and it won't jump off even when loose, I have an oval ring that creates a lot of slack at some points but has to get really baggy to bounce off.
Im left wondering why we need a thick/thin sprocket at all???
Can someone explain to me why a properly adjusted SS would need it? Do people have any real sproket trouble that they need this
I too run an oval ring, and even when at its slackest point is still very secure
No 17 or 19T, not able to do thick/thin. Even numbers only
No chance, not at £150+ or whatever they went for..
A super-hardened cr-mo, Boone-styled oval 34 ring, I'd pay a bit for one of those if anyone made one. Al stuff on a SS isn't great really, don't see any point in using an Al sprocket. Agreed that it's a nice option for some at a fair RRP, ie better one NW option out there than none.
I've not used one of them but I've had a couple of chain rings from marcin at absolute black. One 34t thick thin for xt cranks and one regular 33t on a 94bcd for fsa carbon cranks.
Both are beautifully made and marcin was super helpful and I'd recommend him.
never had a ss chain issue until i deliberately let it go very slack, using several brands down to £5 shimano rear rings, only need thick thin on the front if running 1/10-11 set ups without a chain guide, more marketing hype
