taping jones loop bars...how?
anyone know the best way to tape jones loops.
got 2 sets of bar tape, but whenever I tape bars it always comes loose.
any pics of some taped?
Backcountrybiking
Re: taping jones loop bars...how?
Post by Backcountrybiking »
Check out Jeff's blog
he did a how to not so long ago
Andy
http://www.backcountrybiking.co.uk
UK distributor of Revelate designs gear, Alpacka rafts and Force ten tents and provider of bikepacking and packrafting skills training courses and adventures and Packraft hire
Brothersmith
Post by Brothersmith »
Backcountrybiking wrote:Check out Jeff's blog
Andy
Here it is;
http://www.jonesbikes.com/?option=com_w ... &Itemid=58
I do mine slightly different as I use the loop a lot. I tape the standard part of the bar first. I start by wrapping a small bit of tape over the join of the conventional bar part with loop section, this hides the join when wrapping the loop later. Then I tape the conventional part of the bar from the join with the loop towards the stem. Once this is done I build up the gap between the brake levers and bar grips (Cork or ESI Chunky grips work well) with some bar tape. I then start by taping over the end of the grip, then towards and over the brake lever and up towards the top of the loop. I leave enough space for accessories and the top of the loops. Depending on how far you tape the conventional section of the bar you can just about get away with one roll of bar tape.
This is the best picture I could find of my bars taped.
thanks for the link brothersmith.
Interesting. I've been thinking about taping up a bit more of my loops. At the moment I have the levers fairly in-board and no gap from the grip to lever as I got some of these
http://www.sjscycles.co.uk/grab-on-foam ... k-prod422/
and cut two to length.
99percentchimp
Post by 99percentchimp »
Really nice example of neat taping by Ian.... I tried to get mine like this but it wasn't quite this good :)
It's a wrap by ianbarrington
Conquistador of the pointless
