Aluminium pot, non-stick frying pan, pot handle and brass burner
Used but in good condition
£14 posted
Mini Trangia by cnarborough, on Flickr
M Kettle
Similar to Kelly Kettle in concept, this is a wood fuelled water boiler. Double walled aluminium construction with a container at the bottom for the sticks/twigs for fuel. Water is held in the outer chamber around the chimney and it will boils a pint of water in a few minutes. Neoprene sleeve insulates the outside so you can pour the hot liquid.
http://www.mkettle.com/
£25 posted
M Kettle by cnarborough, on Flickr
