This bannister type barrier is work in progress but it will be strong (rest assured, over engineered and all that jazz
So once this barrier piece is aligned and made (think of the hole in the floor at the top of the loft hatch stairs). Rather than screw it straight into the joists, thus causing me grief each time I remove and reattach, I wondered whether I could use some sort of machine screws so as not to be disturbing the lovely grained wood.
Thankfully as I contemplated the subjected, this pooped up in front of my eyes. Surely they are not that strong as a fixing? Second question is that is it more appropriate to chemically fix in place with epoxy or similar appropriate other!
Perplexed and when the wife gets back I'll be in trouble for not having made progress (and worked on my normal wooden box work).
