HUNT 35 Carbon Gravel X-Wide Wheelset 700C
Tomwoodbury
Post by Tomwoodbury »
These have seen very little use - purchased in nearly new condition and I’ve done one ride on them before deciding I prefer 650b on my Fairlight.
Details as follows:
Centrelock (I think convertible to 6 bolt)
28 spoke rear / 24 spoke front
Microspline freehub
100 / 142 mm thru axle
Spare spokes provided
I’ve binned the original boxes but have a pair of wheel boxes to send in. Currently £629 new but RRP is more.
https://www.huntbikewheels.com/products ... aixUaMCS8X
Looking for £350 plus postage. Message me for pics.
Re: HUNT 35 Carbon Gravel X-Wide Wheelset 700C
Hi Tom
Do you know if the freehub can be swapped for a shimano hyperglide? I know they just pull off but not clear on the website if the hub body and spindle is the same for microspline, sram or hyperglide
Phil
fatbikephil wrote: Wed Apr 02, 2025 8:39 pm Hi Tom
Phil
I think you'll be good, Phil: the hub is the same but you'll need another axle end cap to go with the freehub as the microspline one is different to the HG one.
Tomwoodbury
Pretty sure that they are interchangeable with relative ease
https://www.huntbikewheels.com/collecti ... 2DchoQn4dB
Thanks Tom and Hyppy for the info - I've a pair of all seasons on just now so trying to work out if the freeehub will transfer over. The link above takes you to the standard Gravel 35's which seem to have different hubs to the 35x's.... Any idea how old they are?
I also seem to be running my tyres at too high pressures given the pressure limits on both these and the all seasons!
Defo interested but need some further rumination and I'm away all weekend so will get back to you on Monday either way. Drop John Allan a pm as I think he was after some more wheels
Tomwoodbury
Here’s the blurb… they have slightly larger logos on the rims than the ones being sold atm but specs seem the same:
Freehub - Shimano Microspline
Rims – 700c, Width- 30mm external, 23mm rim bed. Disc-specific. 35mm deep, Tubeless featuring H_LOCK bead-seat for easy and secure tubeless installation. Also works with clincher tyres and tubes
Hubs - HUNT 4Season Disc J-bend spoke hubs with extra bearing shielding. 5 degree Rapid Engage 6-pawl freehub, Centre-lock disc mount.
Hi Tom
Thanks for the info, however I'm going to pass as I'm still ruminating on options
Phil
