2023 WTB Venture 650bx47. It has had approx 35km on it before a piece of flint went straight through the middle of the tread. It was the first tubeless failure I've had in years. The gash is straight and approx 10mm x 5mm. I have stitched it closed and patched it on both the outside and the inside, but you are advised to check the repair yourself.
I ordered a replacement before I repaired it as the BB200 was coming up. As a result I don't need three of the same tyre and it's "Winter Cleaning" season at our house so it along with a load of other things that aren't used have to go.
As it's a damage repair, it's at your own risk. I don't want any money for it, just cover the postage unless you are in Hampshire and want to pick it up.
D
Free Tyre, Cover the Postage
