Campag disc caliper
Sajama
Campag disc caliper
Post by Sajama »
Has anyone had trouble bleeding ekar brakes. 4nm is the bleed port setting on the caliper rounded off the nut with a good 8mm spanner. Must have been horsed up way above the recommended settings.The port on the lever is 5nm and it was ok . Finally opened it with locking pliers, fixed now. Another issue is bleed kits, the syringe and tube is a loose fit. Had to use a silicone tube instead of the plastic tube.
Compared to older XT brakes they are a pain to bleed.
