Osmand v maps . Me
Rasta
Osmand v maps . Me
Post by Rasta »
In the past I used Maps .me but it kept playing up and used a lot of data. Constant pestering to update. Bloated. :sad:
Anyone tried Osmand?
Or similar?
Android. Offline maps. Gps. Don't need routing or anything fancy. Free. Private, no email or logging in.
Thanks.
Re: Osmand v maps . Me
When you have a data signal Rasta. You know you can download a heap of map area via Google Maps and then use then to locate yourself via GPS offline.
I do similar with Outdoor Active and it works well. But I think the option I use is generally a paid sub.
I've used OsmAnd and I like how easy it is to download map sectors locally and that it will do turn by turn on and off road. It has a bit of annoying niggle I've experienced on multiple phones (been using it since 2016ish) is that it won't close. You can force close the app and it still runs in the background. Still, it was free. If you stomach paying 20 quid Backcountry Navigator is perfect and has proper OS Maps.
PaulE
Post by PaulE »
Mapy.cz has worked well for me - a bit basic interface, but fairly kind to the battery and works nicely.
Rasta
Post by Rasta »
Thanks for the replies.
I don't like to use Goog maps as I like to save big areas/whole countries in one go.
Is there a way to turn it off if it runs in the background? I hate being tracked.
Yku can stop google tracking you( not sure whow that works if using their maps but I ssume it just does not keep.a record ) but you would need to search online how to do it
Inise memory map.and its an app with maps downloaded to the device ( needs internet to do this) so works off line
You can pay annually( updates ) or a lifetime(.does not update) and 1:25 or 1:50 or both
I do the later and after 20 hears thebkdd new housing estate exists on roads but no issue off road
The massive advantage of OSMAND is that you can add to the map if it is wrong/missing information by becoming an OSM map editor. It's a great app and is privacy focused whereas Google will use whatever workaround they can to get your data.
Google Maps Timeline & Tracking settings:
https://support.google.com/maps/answer/ ... %3DAndroid
To save Google maps offline, search for a place, the tabs at the bottom have a "more" option. Select "download offline map" and them move the map about and zoom in/out to get what you want. You can easily download all of Wales in one go for example.
