Other than some scrapes and marks to the frame it's in excellent shape, having not been ridden in 18 months. The wheels/rotors/tyres, handlebars, saddle, chain and cassette are all brand new. I'm 5'10 and it's a great fit, couple of inches either way should suit. Brakes are upgraded to Hope Tech X2 and the shifter is XT for multi shift.
Spec as follows:
Frame
TFS - 6061 series double butted and technoformed aluminium tubing with smooth welding. Modern trail bike geometry. Class leading, premium technologies such as Boost axle standard, tapered head tube, inboard disc mounts, internal cable routing.
Fork
Marzocchi Z2; Air; 140mm travel; Tapered; 44mm fork offset
Headset
Merida M2331
Stem
Merida Expert TR; aluminium; 35mm diameter; 0 degree rise - Length : 50 mm
Handlebar
Merida Expert TR; aluminium; 780mm wide; 20mm rise
Grip
Merida Comp EC
Brake Type
Hydraulic disc
Brake Lever (upgraded)
Hope Tech X2
Brake Calipers (upgraded)
Hope Tech X2 with Shimano RT10; 180mm rotor
Tyres
Front: Maxxis Dissector; 29 x 2.4; Kevlar bead; folding; TR EXO Dual Rear: Maxxis Dissector; 29 x 2.4; Kevlar bead; folding; TR EXO Dual
Wheel Size
29
Wheels
Rims: Merida Expert TR; 29mm inner rim width; Material: aluminium; Tubeless ready (tubeless taped and valves not included) Spokes: Black stainless Front Hub: Shimano MT400-B; 110x15mm; 32 spokes; Centerlock Rear Hub: Shimano MT410-B; 148x12mm; 32 spokes; Centerlock; including removable lever with 4/6mm Allen key
Speeds
12
Rear Derailleur
Shimano Deore M6100 Shadow+
Shift Levers (upgraded)
Shimano XT
Chain
Shimano Deore
Cassette
Shimano Deore M6100; 10-51 teeth; 12 speed
Chainset
Race Face Ride; 32 teeth chainwheel with 175mm length crank with Mr. Control CH-CM1 chain guide
Bottom Bracket
Race Face BSA 68/73 - 24mm
Pedals
Nukeproof Horizon
Saddle
Merida Comp CC with saddlebox containing Merida Multitool
Seat Post
Merida Comp TR; 30.9mm diameter; in-line; 150mm drop with Shimano SL -MT500-IL lever
Any questions please get in touch
