High mount bottle cage?
Anyone know of a bottle cage with the bolt holes right at the bottom, so the cage essentially mounts very high up?
I know of the little bar things that move cages up or down, these are the second best option :grin:
yourguitarhero
Re: High mount bottle cage?
Post by yourguitarhero »
You could drill your own hole in the correct place, as long as there is some material to drill through?
Yup, happy to do so if I find a cage with a big enough base
I have also just found the wolf tooth morse cage... but its £40 for a bottle cage!!
King Cage do one in SS or Ti. I use the opposite version to lower rather than raise.
ootini
Post by ootini »
FLV wrote: Thu Feb 22, 2024 12:11 pm Anyone know of a bottle cage with the bolt holes right at the bottom, so the cage essentially mounts very high up?
I found my Specialized Roll cage mounted low, and thus pushed the bottle quite high.
https://www.tradeinn.com/bikeinn/en/spe ... lsrc=aw.ds
Mart
Post by Mart »
Could always use a wolf tooth B Rad to adjust position upwards
samwise
Post by samwise »
Widefoot jist released their new StoutCage....
https://widefoot.com/product/stoutcage/
samwise wrote: Thu Feb 22, 2024 9:12 pm Widefoot jist released their new StoutCage....
Does it hold a can of Guinness?
:lol: well played
chris n
Post by chris n »
Profile Design Kage has high and low mounting holes already
RobLyon
Post by RobLyon »
I just bought 2 of these but not used them yet. They have 3 bolt holes in them but aren't evenly spaced but the lowest is right at the bottom then 2x normal position. Also the silver bar doesn't move, its a plastic ring not rubber and it's only cheap elastic. The reviews seem positive though.
https://www.sjscycles.co.uk/bottles-cag ... ttle-cage/
Actually that plastic loop doesn't go over any bottle i've just tried and your generic high-5 bottle is too small to fit, its 1.5-2l bottles only
