So, had to remove my fork to box up the biketoy home, just need to refit it.
*think* I saved all of the spacers in the right order, just want to double check. Any diagrams anywhere?
The Hope site isn't that clear
Hope Headset Fitting
Re: Hope Headset Fitting
Put your headset in the fridge to make fitting easy.
Zippy's 3rd hand heard it down the grape vine top tip of the day
Ground up-
Lower race
Lower bearing
Lower cup
Upper cup
Upper bearing
Upper bearing race
Thin spacers (use as many to get snug fit of upper cap without drag from the rubber seal)
Upper cap
Stem spacers
Stem.
Lower race
Lower bearing
Lower cup
Upper cup
Upper bearing
Upper bearing race
Upper cap
Stem spacers
Stem.
