The dullest question I've ever asked (Garmin Dakota mount)
I want re-usable zip ties for the Garmin mount (holds a Dakota) that fits on the stem / bars.
Can anyone tell me the width of slots / size of zip tie that will fit? I seem to recall the ones that came in the box are quite skinny and I don't have any of it it front of me to check.
I hope someone stayed awake long enough through this dull requeest to be able to tell me :?
Re: The dullest question I've ever asked (Garmin Dakota moun
I'm easily entertained ;) ... slots are 5.2mm.
Easily but expensively (I saw the price of gimp masks!). Anyhoo, thanks for that, saved me buying the common but too big size. In the spirit of mutual back-rubbing, would you like some?
I was taught at a very young age, never say no when a man you've never met offers you reusable cableties :shock:
Ta
This thread was more entertaining than I was expecting it to be :lol:
welshwhit
Post by welshwhit »
May be too late, but I tried some of these and found that ether the ones I had were rubbish, or they just don't tight enough!
Mine rotated loads over every bump
Drew
Chew
Post by Chew »
welshwhit wrote:Mine rotated loads over every bump
If you only use cable ties on the bars this will happen reguardless of the cable ties. Wrap a piece of old inner tube around your bars than attach the mount on top
welshwhit wrote:May be too late, but I tried some of these and found that ether the ones I had were rubbish, or they just don't tight enough!
Drew
This is why people should write reviews and give us detailed (german-stylee) specifications. Haven't you seen the peg review?
:x
I'm sure mine will be fine :?
restlessshawn
Post by restlessshawn »
I put a blob of silicone on the bars, sit the mount on that, then zip tie on and wait for it to set, no more rotating all over the place.
I also had to stick a felt pad, like you put on chair legs, on the back of the garmin (etrex), to make it an interference fit in the mount and stop it ejecting on drop offs. I still have a saftely lanyard too just in case.
Not the best mounts are they :roll:
ericrobo
Post by ericrobo »
CheekyMonkey: re-usable zip ties... what did you get and where from please ? And do they work ok ?
Seller: kenable_ltd ( 597639 )
Item title Price P&P price Quantity Item total
Natural Reusable Cable Ties 4.8mm x 200mm Pack of 50 (item: 380394376080)
£2.99
Royal Mail 2nd Class
I only ordered them this morning so it's a bit early to comment on how well they work ;)
