16" 45650b frame 27.5 wheels
Fox 32 Evolution 150mm (remote adjuster topcap, but i don't have the remote anymore).
Deore 10spd 2x groupset
SLX Brakes (new pads)
XT bottom bracket (fairly new, hardly ridden since changed)
Specialized command post dropper ( I drilled the frame to take the cable into the seat tube, has a rubber grommet to seal hole with cable)
Superstar Tactic rims on green superstar switch evo hubs
Continental Trail King black chilli tyres 2.4 front 2.2 rear. setup tubeless (both fairly worn but a little life left) 135x10mm QR bolt through rear. 100x15 front.
Bontrager flat bar
FSA gravity stem
DMR v8 pedals
New black lock on grips
The frame originally had blue logos. I covered these with black film and put green logos over the top. so at least the frame has had some protection in places. This could be removed to bring the blue logos back out. there are definitely a few marks and scuffs on the frame. hopefully the pictures show these. give me a shout if you want any more.
the bike has recently had a full strip down, regrease and new cables. it does look a bit scruffy but works nicely.
Based in North Essex if you want to have a look. I could post for cost of courier also.
£320
