DIY poles
DIY poles
I have a number of high spine carbon field archery arrows that are now too short for me. Is there a way bodging a set of poles using standard pile inserts and a suitably threaded jointing piece? I have some blunts that will do as feet.
Re: DIY poles
You may find they're too flexy once a reasonable length. 5/16" I assume?
Re: DIY poles
300 spine though
Re: DIY poles
All you can really do is try it. For joining them together, I'd be tempted to try and find something with an ID of the shafts OD and make external spigots.
Re: DIY poles
See if I can do it ready for bb200
Re: DIY poles
Eventually got round to it.
320 spine heavy hunters. Used long inserts with the end cut off glued half in as the joining piece
Quite stable in the back garden with a shaped tarp
Cut to 10" lengths. Used protector rings so they won't split. Rubber blunt end to stop them ripping the fabric
4 lengths for the front, 2 for the feet, surprised how well it works
Just over 100g
Just over 100g
