Framsets (Sonder, Surly) + QR Dynamo Wheelset
vdubber67
Post by vdubber67 »
Sonder Frontier frame and forks in XL. If you look closely you can see they’re different colours ;) £175 posted. This is a 29er, Boost frameset. Some wear and tear as befits a ridden frame, but it has had a chain stay protector on.
Surly Karate Monkey Frame and forks in XL. Frame has been resprayed and re-stickered a while back. It’s by no means a pro job, and has been used since painting. Once again, a careful inspection will reveal that I didn’t paint the forks – ;) £225 Posted. This is a QR, non tapered frameset with a mech hanger built in, but would also run SS. Has the cable run adaptors to allow for a full hydraulic brake cable run and a seat clamp.
29er QR Dynamo Wheelset. Both rims are Alex rims, 622X21. Front hub is a SP dynamo, rear is a Shimano Deore. The dynamo worked and powered a light before I stripped the bike. Bearings good, rims straight. £75 posted
Pick up from near Notts is an option.
Drop me a mail if you’re interested. rtedgeAThotmail.com
Can send pics, or have a look on STW ;)
Ta
