WTD: Band-on Chainguide (Sorted)
Before I buy some cheap arse band-on chainguide off Amazon or eBay. Don't suppose anyone has one kicking around the bottom of their parts bin they'd be willing to part with...? To fit a 35mm or there abouts downtube...
Re: WTD: Band-on Chainguide
I have a Paul's chain guide if any use ( it's clamp on though ) but usual Paul's quality / over priced
Any use ?
Any use ?
One of these...? As long as it's the 35mm version and you're pretty much giving it away (how much...!?!
), then yes.
I might have some Bob - don't suppose your frame has guide mounting tabs on does it?
EDIT: found a lovely Gamut guide Bob but it's BB and / or tab mount.
Yes one of those and I will measure it in the next half hour or so - not quite give it away but in all honesty it just sits in my parts bin waiting for someone who wants it so very very cheap
Assuming it's the 35mm clamp version, and it's no more expensive than buying a no brand Chinese one off amazon, then I'll take it off you hands.
No mounting points, or cut out in bb shell for a tab. If Lazarus's isn't right, then I'd defo be interested Stu.Bearbonesnorm wrote: ↑Tue May 31, 2022 7:59 am I might have some Bob - don't suppose your frame has guide mounting tabs on does it?
Can you drop me a PM with your e-mail and i will send pics
the actual thing says 31.8 on it - which i assume means seat post size as i am able to clamp it on my 35mm external diameter tube - without any problem and its secure - hence the need to send you photos.
Price a tenner + post so must be change from £15 i assume - i probably wont get it to you as fast as Amazon though but i am far more ethical
Sorted now. Thanks for looking Stu!
