SOLD Salsa El Mariachi frame and forks REDUCED TO £350
chris n
Post by chris n »
NOW SOLD
17"/medium Salsa El Mariachi frame (2014 model) with Firestarter fork
£350 posted in the UK or collect from central Bristol
135mm QR rear axle with adjustable dropouts for hub gear/SS
44mm head tube
Hope lower headset
Cane Creek upper headset
100mm QR fork, 1 1/8" steerer
Salsa seat clamp, takes 27.2 post
Very good condition with a couple of strap rubs to the fork crown and minor paint scuffing. One small chip to the seat stay bridge.
chris n
Re: Salsa El Mariachi frame and forks
Post by chris n »
Non-drive side
chris n
Post by chris n »
Seat stay bridge
chris n
Post by chris n »
Drive side dropout
chris n
Post by chris n »
Non drive side dropout
chris n
Post by chris n »
Fork crown
chris n
Post by chris n »
Geometry
AlasdairMc
Post by AlasdairMc »
I’m surprised this hasn’t generated more replies as there’s a lot of love for the El Mar on here. I’ve got exactly the same as you’re selling here, and it’s just lovely.
I'm looking at it a dribbling a bit.
Is it 26 or 29 inch wheel?
(In reality, as I will very soon be living off savings, I can't splash money on a frame I technically don't need)
slarge wrote: Fri Jan 07, 2022 10:52 am I'm looking at it a dribbling a bit.
My 2012 is 29er so I'd say it's likely to be a 29". You really should buy it, can't call yourself a proper bikepacker unless you have a Salsa in the shed :wink: The versatility of the dropouts means you can keep it for life and switch to suit. 135 QR, 142x12, single-speed, rohloff.
Defo a 29er
I sold my El Mar a couple of years ago, was a sad day. Wasn't getting ridden and was too similar to my Solaris except for the drop outs. It's a cracking bike. I rode is SS and with an alfine. Mine was a similar vintage I think
One day I'll have a singlespeed again
Escape Goat
Post by Escape Goat »
sean_iow wrote: Fri Jan 07, 2022 11:34 am
This is good news. I didn't realise I could make the rear 142 on mine.
Escape Goat wrote: Fri Jan 07, 2022 1:55 pm This is good news. I didn't realise I could make the rear 142 on mine.
Just need to buy the correct pair of alternator swing plates, it was the first thing I did to mine* I'm sure Keep Pedalling will be able to order them.
* Technically mines a Selma but it's the SS Ti El Mar in all bar name.
Escape Goat
I've called mine the El Mariachi Band heh.
chris n
Post by chris n »
slarge wrote: Fri Jan 07, 2022 10:52 am Is it 26 or 29 inch wheel?
29" - I think you'll get up to 2.4" in the frame. Loads more space in the fork.
I've one. It's one of the few bikes I'll never get rid of.
Never had gears on it, but it was never intended as a geared bike!
chris n
Post by chris n »
I'm only selling it as it's slightly too small and I've just bought another bike that does everything this does slightly better - I don't ride MTBs enough to justify having two so similar... It's still a lovely frame and rides really nicely.
atk
Post by atk »
I wish this was a little larger. Always wanted one, ideally in orange too. Sadly I have enough slightly-too-small singlespeed bikes already :roll:
chris n
Post by chris n »
Bump. Reduced to £400 posted. Will split.
chris n
Re: Salsa El Mariachi frame and forks REDUCED TO £375
Post by chris n »
Bump. Reduced to £375 posted.
Tomwoodbury
Post by Tomwoodbury »
Quite tempted by this now. What’s the tyre clearance on frame and fork?
And can it take a triple chainset?
chris n
Post by chris n »
I think you'd get 2.4" in the back - I used it with 2.1". Fork is 3" or more.
Standard 73mm BB, no problem fitting a triple - though I only used it as SS or 1x. Has cable routing for front mech.
Tomwoodbury
And does it come with a plate for 142mm bolt through?
chris n
Post by chris n »
No, only what's shown in the pictures.
Escape Goat
Tomwoodbury wrote: Sat Feb 05, 2022 11:34 am Quite tempted by this now. What’s the tyre clearance on frame and fork?
Yep. It takes a 2.4.i have a 2.4 rekon on the back of mine on a 26mm internal rim.
