Shimano GRX brakes to post mount
Chicken Legs
Post by Chicken Legs »
Looking for the correct adapter to install Shimano GRX brake calipers to post mounts front and rear with 160mm rotors.
Found Cinq adapters which are nearly as expensive as the brake calipers :roll:
Is this the cheapest/only way to do it ?
https://www.sjscycles.co.uk/brakes/cinq ... m-caliper/
Re: Shimano GRX brakes to post mount
Yep - that's basically the answer.
Loki
Post by Loki »
Alternatively and just as expensive, remove and sell the caliper and fit Hope?
Simon K
Pete-G
Post by Pete-G »
Loki wrote: Fri Oct 15, 2021 8:18 am Alternatively and just as expensive, remove and sell the caliper and fit Hope?
or some regular shimano post mount calipers. Pre flat mount, thats all the ultegra level kit was.
