Cable disk brakes and 700c wheels
yourguitarhero
Post by yourguitarhero »
Shimano Tourney TX Cable Disk Brakes
£25 posted
DT Swiss R23 Disk Brake Tubeless 700c Wheels
Set of nice DT Swiss wheels. Only selling as I upgraded to lighter Mavic ones.
They are 1.63kg for the pair, 18mm internal width, 23mm deep rims, 20/24 bladed straight pull spokes. Hubs can take most axle standards, have a Shimano freehub and take centrelock rotors.
Specs here (Scroll down): https://www.mantel.com/uk/dt-swiss-r23- ... d-wheelset
I’ve run them with both tubes and tubeless. The rear rim has a couple of dings in it but still holds air tubeless no problem.
Currently set up with 15mm adaptors in the front and 10mm QR/Thru at the rear (a sort of thru axle that fits standard QR dropouts) – I’ll chuck in the rear axle.
£150 posted
I can also do a pair of almost new Mavic Yksion Allroad 28mm tyres for another £20.
