Cairngorm's question!
HUX
Post by HUX »
Does anyone know if the track that heads north from Dalnacardoch Lodge ( on A9 glen Garry), past loch an Duin, Gaik Lodge,into Glen Tromie and ends at Tromie Bridge on NCN route 7 is rideable with a BOB trailer.Looks good on the map just wondered if anyone knows it. Im heading up there next week and want to try and get some off road done and that will cut out some of the road. Cheers
Dan_K
Re: Cairngorm's question!
Post by Dan_K »
I rode it last week and it would be fine until probably Loch an duin. The land rover track and bridge is washed away and so you have to cross at the footbridge slightly further north west and then hike over the frozen/boggy scrub to get back on the pathway by the loch.
Depends how determined you are tbh. I think apart from that section, you'll be fine.
HUX
Post by HUX »
Cheers for that Dan-k,I don't mind a bit of a push so i'll prob give it a go. Good effort on your trip BTW.
Dan_K
Post by Dan_K »
No worries. The footpath by the loch is quite narrow, rocky and technical in places but if you don't mind a bit of pushing, the wilderness and views are well worth the effort. My snowy pictures are from that path.
