Howdy,
I'm looking to replace some road/gravel/drop bar levers/shifters and hoping someone can suggest options that aren't crazy expensive!
Needs to work with cable discs (TRP 'Spyre') and Shimano 2x11 drivetrain.
Anyone? Anyone?
Thanks in advance.....
Non-bank-breaking drop bar shifters/levers...
Re: Non-bank-breaking drop bar shifters/levers...
ow many speeds?
I use some 105 in the hydo version which work well (rattle a bit without the left one connected to a front mech)
I hear good things about microshift but they done look loads cheaper than 105
All 11 speed
All 11 speed
they are considerably dearer than MTB stuff arent they - thats a no from me
Bar end shfiters or a MTB shifter* to change gear - if you can stomach the aestehetics /make it work [ probably need a shift mate ]
* what i did as i had hydro discs and no way i could pay the price[£150 ish] required to just chage gear on a front mech
- gairym
I've already got an XT mtb shifter (sawn-off) which is mounted to the bars via a Sram mount for the rear mech and it's great but I thought I might switch to something more 'traditional' now that I want to go 2x (currently ghetto 2x with me needing to adjust the limiters on the front mech that's being used as a chain device).
#sketchymechanicsoftheworldunite
Tiagra 4700 manual has the same cable pull as 11 speed
