FS - SRAM gears and brakes WTD: XT Cranks
Hi all,
I upgraded from SRAM GX 11 speed gears to Shimano and also SRAM Level Guide brakes to Hope, hence I have these parts for sale:
SRAM Level Guide TL - front and rear set (the rear needs bleeding as the hose was routed internally). Condition is used and very good (but not perfect) - some scrapes on the caliper. Pads are good. Post mount, and ideal for 160mm rotors.
£50 posted for front and rear set.
SRAM GX 11 speed shifter and rear mech - condition is used, the shifter is immaculate, the rear mech has a couple of scrapes. Both fully functional and unworn (no visible wear to the jockey wheels). The shifter bracket and the brake bracket is integrated to a single clamp.
£75 posted for shifter and mech set
Wanted:
XT Crankset for a triple ring setup. Ideally 170mm M760 or later, but not too fussed. Just needs to be external BB axle compatible. Condition not too important.
drop me a line to: stevelarge66 at gmail dot com
thanks
