Anyone using Salsa carbon forks ?
the ones with the cage mounts on ?
just wondering how secure they are with cages mounted and stuff lashed on.
Re: Anyone using Salsa carbon forks ?
Really depends on the cage and what's in them Tony. Most have a weight limit but if ever I use cages, I always try to pack the least weight and most bulk in them. You can sometimes have problems catching them on tight trails and I've found they do a reasonable job as acting as a wind brake.
I have Travers Prongs with the fork mounts but despite having all the kit to mount stuff too them, haven't actually needed to
I always think they looks quite 'expeditiony' and my trips usually involve too many pubs/cafes to be classed as those. Not judging others though :-bd
i was gonna mount a bivi on one side and a kip mat on the other, but had thoughts of em snagging trailside and ripping the mounts out of the carbon.
and the 2 items in a waterproof bag fit under my bars very nicely. i think that is the way to go.
cheers.
substandard
Post by substandard »
I’ve got a pair of their carbon fatbike ones with the 3 threaded mounts on each leg, never had anything come loose using them.
Mactheknife68
Post by Mactheknife68 »
Have you considered the Tailfin S3 rack , does away with the need for an expensive seatpack as you just strap a drybag of your choice to the top and then the struts have bosses for cages or just use voile straps and strap drybags to them.
https://www.instagram.com/p/CMUPShwLgs4 ... 6qtmd8b9ci
https://www.instagram.com/p/CNQfjfBBCQ_ ... o5brise4c0
Gari
Post by Gari »
Am I missing something re the tailfin? It seems to be around £150, which is as much, if not more than most seat packs?!
But I think the Tailfin comes with its own mug hook.
Gari
Post by Gari »
Right, missed that sorry!!!
I got to an eye watering £579.00 for the X series with bags and side bags and axle [ non frame mounting ]
For the rack alone I got £279- S series a very reasonable £250 with mounts
WhoTF is paying that for a rack ?
Its the R@pha of racks that
YMMV
Yes. I’ve only ever used them road touring. I’m not a fan of anything on my forks that changes how my wheel steers!
i decided to go for a bar mounted solution.
cheers all.
ton wrote: Sat Apr 17, 2021 8:53 pm i decided to go for a bar mounted solution.
A handpump and two optics?
Gari
Post by Gari »
