Hi all, does anyone have a Dynamo hub (SP) that they don’t want? 32 hole and QR hub, not fussed whether disc or not or whether the bearings are shot. Will be replacing a non working hub in an existing wheel.
Ideally something you’ve given up on and want to offload..... therefore cheap!
Sp Dynamo hub wanted
- Dave Barter
Re: Sp Dynamo hub wanted
Yes I think I have one currently on a 650B rim. Bearings are a bit dodgy but still working. Only thing is that it is bolt through, I think there are adapters? If so you can have it Steve. I’ll check properly tomorrow
That might be brilliant Dave - I'll check the QR adaptor situation also.
Thanks fella!
Thanks fella!
- Dave Barter
pm me your address Steve and I’ll post it next week
You can get adapters for them [15mm to QR] - i got one from ebay and it works fine,
