Surly Straggler 54 cm - premium spec king / home / thomson
ad3000
Post by ad3000 »
Selling my surly straggler as is not getting much use. It is in great condition and has a high spec. Pics in google drive here https://drive.google.com/drive/folders/ ... sp=sharing
Looking for £1250 collected, happy to post but would be going by paisley freight insured and buyer to cover costs. I would need a few days to source a good box.
Frame & Fork: Surly straggler 54cm, decals removed
Headeset: Chris king
Wheels: Hope pro4 on stans grail, hope QR skewers
Tyres: Kenda small block 8, setup with innertubes
Brakes: TRP spyre, avid levers
Rotors: hope floating road 160mm
Seatpost: Thomson
Stem: Thomson 100 mm
Handlebars: Thomson trail AL
Cranks: FSA carbon
Bottom bracket: Chris king
Rear mech and shifter: Shimano Sora, dura-ace downtube shifter
Saddle: Fizik
Mudguards: SKS
The only faults are (as pictured)
1. One of the bolts that can be used to set axle location in the dropout has sheared. It could likely be removed with a set of molegrips and precision but I have never had to use it in either geared or ss configurations so have left as is. I have spares should you choose to do this.
2. There are some scratches on the innerside of the chain stay
3. There is some cable rub on the fork crown / headtube
