Seam sealing a sil-tarp
InspiredRamblings
Post by InspiredRamblings »
Hello...
Thought it was about time I got my tarp (ID Sil-Tarp2) out of its bag and started making it ready for use. Have some line and line locks and a tube of SilNet.
Two questions...
1. The SilNet instructions say to apply the sealant on the inside of the seam. Any views on that? Is it worth doing both sides?
2. Obviously I need to do the main seam running down the middle, and the stitching around the tie out point on that seam, but should is it also worth doing the seam running around the perimeter of the tarp, and the stitching around all of the other tie out points also?
I'm expecting a 'No' to Qu 1 and a 'Yes' to Qu 2, but we'll see...!
Thanks, Chris
Salsa Horsethief XT (2020)
Jamis Dragonslayer (2016)
http://www.uninspiredramblings.com
Re: Seam sealing a sil-tarp
I'd just do the main seam and I'd do the outside ... just don't expect it to look pretty ;)
Anthony
Post by Anthony »
You can apply masking tape to keep it neat if that sort of thing bothers you!
Not much point doing the perimeter, after a few metres you'll be bored anyway.
InspiredRamblings
Ah - the owner's manual (obviously it was easier to post a question here than actually look at the manual), says:
"For a complete seal, spread the minimum possible amount of sealant evenly onto all needle holes, thread and fabric joints on the inside of the fabric".
I was thinking that doing the perimeter might get a bit dull. And I might run out of sealant :roll:
