Replacement Derailleur Hangers
Fixed a puncture while out on a ride yesterday, but while getting my stuff together afterwards, the wind blew my bike over and it landed on the rear derailleur. I spent the last 10km home, with the chain skipping all over the place and upon inspection, it looks like there are some small crease marks across the hanger. I'd been planning on buying a replacement anyway, but never quite got round to it, as the only place I've ever seen with them in stock is Bike24; obviously they are now out of stock.
Google has turned up nothing, other than a couple of places in North America, that are also out of stock. I also can't find anything similar on Derailleur Hanger Store. I'm sure there's a similar place in Europe, that I bought a replacement hanger for my old Scott tri bike years ago, but I can't remember what they're called. Does anyone know of anywhere that stocks something similar to this...?
It's for a NS Bikes RAG+2018 - 2019 model. The hanger for a Rondo RUUT looks similar, but I canny find one of those either...
Re: Replacement Derailleur Hangers
I have found this one, which looks vaguely similar. The description does say Rag (Some Frames) too...
woodsmith
Post by woodsmith »
Here?
https://www.rearmechhanger.com/product/ ... ger-cc178/
Sorry, miissed the part where you said you'd already found this one.
Borderer
Post by Borderer »
I found a tricky replacement recently at BETD. You send them a photo and they will match it. Costs about £20 posted.
https://www.mountainbikecomponents.co.uk/
BETD are my normal go to.
https://wheelsmfg.com/derailleur-hangers.html - distributed by Madison so most LBS will have access to them
belugabob
Post by belugabob »
Buy three.
One to fit
One for your backpack
One for stock
#paranoid
F'ing typical... NS Bikes have them back in stock, but aren't shipping to the UK. Thanks you 🤬 Tory 🤬! So I've gone for that one I shared above, twenty five 🤬 quid...
So... the saga continues. The replacement has turned up, and looks vaguely similar:
After a bit of wiggling, it fits in the frame. The supplied bolt is too short and the countersunk head too large, thankfully the existing bolt fits fine:
However, the thru-axle wont fit, gets about half a turn in, then jams:
Getting royally fecked off at this point...
The thread is the wrong pitch. There's at least 3 rear axle pitches that I know of.
Yup, now to find a new rear axle... 😞
lune ranger
Post by lune ranger »
It only took 8 months to get my Ribble sorted.... you’ll be fine :-bd
Turns out that Hotlines have the correct replacements hangers in stock. 😲
Now to find a LBS that can order me a couple...
Oh FFS! Tried to order two hangers from a LBS just before Easter weekend, sort of forgot to chase them until Wednesday. Chased them again this morning and they managed to get through to Hotlines and then then back to me. Guess what? They're now out of 🤬 stock again...
I'd just sent the one with the wrong thread pitch back too... At this rate, I'd be better off just buying a new bike.
Oh my giddy Aunt, I may have found an actual replacement derailleur hanger. 🤯
Wonders what will go wrong this time -lost in the post ? :wink:
lune ranger wrote: Wed Mar 31, 2021 9:10 pm It only took 8 months to get my Ribble sorted.... you’ll be fine :-bd
Bob... you've not managed to brake Lukes record. That's just not good enough (hope it comes through btw)...
Lazarus wrote: Sun Apr 18, 2021 3:16 pm Wonders what will go wrong this time -lost in the post ? :wink:
If that happens, I'll do the Babalon Working and let Azathoth take over...
redefined_cycles wrote: Sun Apr 18, 2021 3:47 pm Bob... you've not managed to brake Lukes record. That's just not good enough (hope it comes through btw)...
I'm just looking forward to not having to use my sons bike to get this months bivvy in... 🤞
Best get my arse in gear and get the bike fixed so I can get out for a bivvy this month...
lune ranger
Its not fitted yet :wink:
Glad its sorted :-bd
Lazarus wrote: Thu Apr 29, 2021 1:24 pm Its not fitted yet :wink:
If I didn't have to actually do some work today I'd just finish it in a oner, but it's going to be five, ten minutes here and there between meetings...
lookrider
Post by lookrider »
Gearmechhangar.com
Maybe a little too late to help you
They have 100s of them some good photo and info and full size image to lay yours on top of screen for a perfect match
Good luck anyways
lookrider wrote: Fri Apr 30, 2021 9:04 pm Gearmechhangar.com
That had one that fits the bike, but the thread pitch is wrong, so I'd have needed a new thru-axle... 🤷
