29x2.5 all round tyre
- Piemonster
Is there a current stand out tyre in this size?
I’m thinking Highland estate tracks mostly but with some gloopy bits, some tarmac bits.
2.4 as well if that throws up better choices
Re: 29x2.6 all round tyre
Vittoria Mezcal.
- Piemonster
Re: 29x2.5 all round tyre
Edited for putting the wrong tyre size down
2.6, mezcal
2.35, iKON (close enough to a 2.4)
2.25 racing ralph (in case you care)
My current faves.
My current faves.
And the Ardent 2.4 is a bigger tyre than most in that range. Mezcal is a size up from that.
- Piemonster
The 2.6 Mezcal is too big I think.
I have a suitable rear ready (Ardent Race 2.35), and am thinking of something with a little bit more bite for the front. Although I may just be underestimating the Mezcal?
The 2.6" Mezcal is indeed true to size (on i30 mm rim).Piemonster wrote: ↑Sun Sep 27, 2020 7:54 am The 2.6 Mezcal is too big I think.
I don't think so. Whilst I like the Mezcal for different reasons on 'easy' terrain, the tread pattern does what you'd guess from the looks of it.
Didn't like the Vittoria Barzo 2.6" much. Has a stupid shape on i30 mm. Might need a 35 or 40 mm rim, yet it had a significantly narrower profile than the Mezcal 2.6".
I quite liked the Maxxis Forekaster 2.6" in dual compound, which is quite good in balancing wear, wet grip and rolling speed.
Perhaps a bit much grip/rolling resistance for your needs, but in my books a good do it all tyre.
Not true to size on i30 mm rims, it's just a tiny little bit wider than eg Schwalbe Magic Mary in 2.35".
Since Schwalbe has made a new Nobby Nic - which basically is a mini Magic Mary (my fav for biking in the mountains)- I'll give that a try in 2.35 or 2.6" front with probably Schwalbe Rock Razor (again) in 2.35" on the rear since the Maxxis Ikon was just not enough tyre for my regular type of biking and I kept damaging it. Mind, Forekaster is rather sensitive too, but was okay for me up front.
The consequence for their rather light weight...
Any reason not to use an Ardent 2.4? They're not the fastest roller and not for wet conditions but I rate them on dry/loose/hardpack. EXO versions are durable too.Piemonster wrote: ↑Sun Sep 27, 2020 7:54 am The 2.6 Mezcal is too big I think.
I think I'm going for Mezcal 2.35s maybe 2.6 on front for future UK bikepacking stuff. They won't be much good in the wet but I tend to head out on longer rides when the trails are faster-running anyway.
- Piemonster
I think they’ll be what I end up with.Any reason not to use an Ardent 2.4?
A decent compromise.
I’ve just fitted a 29x2.6 barzo to the front and a 29x2.6 mezcal to the rear,
Hoping they are as good as the 2.25” I used to use for xc racing but with added Cush
Spesh Purgatory? Maxxis Rekon? Terravail?
Wanted to say the exact same thing. I've not had a chance to test out this arrangement (new build in progress) but they seem like a good pairing with Barzo out front for dealing with slightly muddier / bite-ier situations...substandard wrote: ↑Sun Sep 27, 2020 1:17 pm I’ve just fitted a 29x2.6 barzo to the front and a 29x2.6 mezcal to the rear
I ended up sending the barzo (and a replacement barzo) back as they we’re tiny!
They measured around 2.3 rather than the 2.6 the mezcal comes up to on the same rims
substandard wrote: ↑Sun Oct 18, 2020 4:07 pm I ended up sending the barzo (and a replacement barzo) back as they we’re tiny!
No surprise...
