ST&G Map
ozboz
ST&G Map
Post by ozboz »
Hiya, has or does anyone use the ST&G adventure map of UK for their BP treks ?
I came across it on the OS site, it looks ok and may save buying multiple OS maps for one trek ,
ozboz
Re: ST&G Map
Never heard of it.
Is there a link?
ozboz
Re: ST&G Map
Post by ozboz »
Re: ST&G Map
Ah, doesn't look like it would replace an OS map. Might be handy for ideas though.
ozboz
Re: ST&G Map
Post by ozboz »
ozboz
Re: ST&G Map
Post by ozboz »
See other link above
Re: ST&G Map
I didn't think they actually contained that much actual mapping detail? Certainly not enough to navigate with.
Re: ST&G Map
I've got the adventure map and there's not enough detail to use it to navigate.
If you're looking for a map that covers a larger area, have you looked at the Ordnance Survey Travel Maps? 1:100000 scale and enough detail if you were mainly on roads. I've got sheet 7 and that covers the whole of Hampshire and the Isle of Wight.
ozboz
Re: ST&G Map
Post by ozboz »
Ok , thanks for replies , so I think I’ll need OS 17 and one more Due South , is it better to buy them hard copy or download on device ?
I’ll need detailed map , same as we used in the Army ,
Re: ST&G Map
I'm assuming you mean OL17 which is northern Snowdonia and OL18 is the map south of it. They're 1:25k so there's plenty of detail. Explorer maps (which these are) feature a code on the inside which allows you to download a digital version of the paper map you've bought to a device ... best of both worlds and a handy back up.
ozboz
Re: ST&G Map
Post by ozboz »
That sounds good !!
