Intended to join the end caps up and make this into a good honest mtb, but have reassessed my priorities in life and this did not make the cut.
Hope Hoop Pro 2 Straight Pull singlespeed hub. Stans Crest 29” 700c Rear Wheel, with SS freehub body.
This has never been used (ridden) but it was fitted to the bike. It has yellow tubeless tape installed and the free hub body spacers. Lovely single speed specific wheel.
£130
Titus El chulo frame large. Lime green
Comes with spare hanger and wiggle bottom bracket and headset fitted and xt cranks with 30t chainring (the largest that will fit due to a planet x mistake)
£120
Built up for the WRT last year and not used since
Could leave on one bars/stem, carbon seatpost and shim, used Shimano deore brakes, and zee rear mech attached for a bit more. Say an extra £50
X fusion slide 29" fork
I twisted the red twisty knob and it fell off. Wasn't totally sure what it did. I'm sure a replacement exists. Everything else worked fine.
£50
I have a like new continental 2.2" folding tyre somewhere. Had King in the name. Probably X king
£15
Giant P-CXR1 -CX - Gravel - Road Disc front wheel
Bit narrow for this mtb but ace for a gravel bike
Hubs made by DT Swiss for Giant (DT Swiss Parts compatible)
Lightweight alloy 700c rims
28 Straight DT Swiss Competition spokes,
Front Hub 100 x 15mm Thru Axle, hub convertible to Quick Release (conversion kit not included)
6 bolts
19mm inner rim width
Tubeless
810g
£50
Stored at my parents in Birmingham so will have to explain to them to take pictures of things, but is possible, there isn't much else to do at the moment after all.
Most of a 29" bike
Re: Most of a 29" bike
Hi,
Do you still have the forks please?
Joe
Joe
Thanks-
might it be possible to get some pictures and a steerer measurement please?
What axle is it for?
Drop me a message and I'll send you my email
Many thanks.
Many thanks.
