Pretty sure that's what it is from memory. A-C is 468mm, offset 45mm. 260mm uncut steerer. IS disc mount. Takes a 29x3" tyre. All the mounts for racks/cages etc. V-brake mounts (blanked off currently but I know I have the studs somewhere so will include). It's been around the bush (Europe) so isn't pretty and has some extra stick on hose guides on the right leg where I ran the dynamo cable, however straight and true.
Gorilla Cages x2 with 5L Lomo window dry bags. - SOLD
They're gorilla cages, they go on your forks or wherever you have mounts. The Lomo drybags work well in them are hard wearing and have no holes or tears.
