Tyre Pump
Tyre Pump
I think that I have understood that low pressure 'fat' tyres are better inflated with a pump that has a wide body (high volume?) and, of course, my pumps are thin bodied road pumps.
What pumps are people carrying, please?
Re: Tyre Pump
I've got some old style of Blackburn MTN in one bag and a Lezyne mini MTB thing in another. Both do the job just fine.
Re: Tyre Pump
Lezyne mini pump here too.
http://www.chainreactioncycles.com/Mode ... elID=24665
Re: Tyre Pump
Like Ian I take a small pump
http://www.chainreactioncycles.com/Mode ... elID=85211
Since I started riding without a camelback I have pared down the junk I carry. The pump is small and I hope I never have to use it !
I dont have 'fat' tyres though, just ordinary 2.0 / 2.1
Re: Tyre Pump
I have a Lezyne pressure drive for road bike purposes (high pressure low volume)
for MTB purposes, a Lezyne something or other Drive - which is in anodised blue bling so I can differentiate it between my road pump. It's a high volume, low pressure jobby.
Top notch quality if a bit pricey
Re: Tyre Pump
I thought 2.0/2.1 was fat. After years of inch and a quarter they look fat!FLV wrote:Like Ian I take a small pump
Re: Tyre Pump
Thanks all.
Those Lezyne look lovely and my lbs stocks their road pumps. I'm in there tomorrow so I'll see what he has hidden away from his roady clientele.
Re: Tyre Pump
I've got the Bikehut branded version of this:
http://www.on-one.co.uk/i/q/TOPHGM82/ph ... floor_pump
Does the job ok and won't break the bank. Much prefer it to "direct to valve" pumps. I've also got some stupidly light BBB one that I take out on my road bike. It'd be a nightmare trying to inflate a flat 29x2.0 with it!
Re: Tyre Pump
I went to lbs yesterday and I was that astounded that he made me a coffee that I left without buying anything.
Went back this morning and looked at the Lezynes (and got another coffee) and got a good price on the Flatfishy one at the top of this thread.
Mine has a gold anodised screw on bit; very bling. :) I'm summoning up the courage to tell Herself how much it cost.
Re: Tyre Pump
...and I've just seen it is a HP not a HV.nobby wrote:I went to lbs yesterday and I was that astounded that he made me a coffee that I left without buying anything.
Does it make a lot of difference?
Re: Tyre Pump
Yes.
HP = high pressure, for roadies.
HV = high volume, for mtb's.
Re: Tyre Pump
I guessed that bit but what's the practical differences?flatfishy wrote:Yes.
Re: Tyre Pump
Think one pump from a HP pump as 5cm of air at 150psi, whereas HV is 50cm of air at 50psi.
Your HP pump will work, but it'll be a lot more work. (plus you'll hopefully never need that kind of pressure)
See if you can swap it?
Re: Tyre Pump
Yep, no trouble swapping it. It's a roadies shop but they've ordered on in for me.Chew wrote:Think one pump from a HP pump as 5cm of air at 150psi, whereas HV is 50cm of air at 50psi.
Ntw, another excuse for an urban snow ride and a Costa :)
