Pillow recommendations
Something has changed with my sleep, my pillow is no longer comfy for some reason. It's the third pillow I've had and I thought I had it nailed, been using it for a while now, clearly not
I'm using an exped airpillow UL, I think. I'm an everything sleeper - side, back, sometimes even my front
The exped is giving me a neck pain during the night, not good. Had neck pain during the night on both WRT nights, thankfully it went away in the morning.
It turns out as I get older I'm becoming more of a princess. I use a memory foam shaped pillow at home, very comfy. Other pillows in other beds (hotels/B&Bs etc) aren't as good. I always used to have great sleep outdoors but my pillow is letting me down
Any recommendations?
(I've seen the exped aeros but can't work it if it's just the new version of my airpillow or its a different design)
Re: Pillow recommendations
I'm still resting my head on a Klymit Cush. It folds over into 2 or 3 so you can adjust the height. Can also be had quite cheaply.
https://www.castlebergoutdoors.co.uk/kl ... gJYtvD_BwE
Same as you Ben I've been using Exped pillows - the "light" one and then the "ultralight". It was OK but wasn't quite right, so I've switched back to my Exped Pillow Pump from ages ago - as the name implies it pumps your airbed then itself! Seems softer than the L/UL ones. And you can leave the schnozzle behind then too (which aren't as light as they should be anyway - 60g? compared to pillow pump at about 130g I think). Worth a try-out at twenty quid?
https://www.gaynors.co.uk/equipment-c15 ... BcQAvD_BwE
Stu's looks interesting. Can be used as a chair as well :-bd . "neat features like 'ear pockets'" - not sure about that bit though, I prefer mine attached at night so I can hear the bears coming for me.
We've got Sea to Summit pillows, one normal size and one (extra?) large.
fatbikerbill
Post by fatbikerbill »
Klymit Cush here and very happy.
Bill's tip of day. Wrap it up in a buff to keep it under control.
In Reverse
Post by In Reverse »
Another Kush user here, although to achieve the full height requirement I also use a pillow drybag like this: https://www.ultralightoutdoorgear.co.uk ... sack-p9836
You in the pub yet Bill?
Richard G
Post by Richard G »
I might try that Kush this weekend. It's been hanging around in a cupboard here for a while.
I tried the Sea to Summit one recently. I hate it.
I also get a sore neck - I just use an ebay one as no air pillow is good enough you actually want to use it all the time so I preferred something that cost pence - surprisingly it weighed under 50 g as well. Its ok which is as high as I rate more expensive options I have tried.
Mart
Post by Mart »
sea to summit for me (smallest size they do is still huge)
Makes a big difference for me - i sleep a lot better
Retiredtester
Post by Retiredtester »
Might be the same as the ebay one referred to above, but I got a simple tyvek pillow (with free inflating straw) from Henge Hammocks for about £3 posted and it served me very well last weekend.
Retiredtester
Leerowe76
Post by Leerowe76 »
Bought a sub standard one from go outdoors for my first overnighter was awful, ebay'd an inflatable one 4.50 posted out worked great over the WRT weekend moves around fully inflated bit of pressure out was sound :-bd
Polisherman
Post by Polisherman »
Yeah, the Klymit Cush is great (and cheap!)
I fold mine into 3 and keep it under control inside a t-shirt. I find the "earhole" comfy!
i've just noticed that i was being a dope - the aeros is made by sea to summit, not exped
While browsing, including looking at the klymit cush, I found the klymit x. Quite like the look of it
Hmmm, actually reviews a bit mixed on the klymit x
But discovered the trekology pillow from amazon, pretty cheap too (similar to the kush)
For the kush users, are you back or side sleepers?
middleagedmadness
Post by middleagedmadness »
Had one of the trekology pillows for a year now ,can't fault it to be honest ,don't inflate it fully and it's really comfy ,( not the kush type but the normal type)
padonbike
Post by padonbike »
Mammut Air pillow. Very light - I think this and the Klymit Xlit 3/4 mattress are just a little over 100g combined. Obviously more comfortable options :grin:
https://www.amazon.co.uk/Mammut-Ajungil ... B0195F9V8C
Oli.vert
Post by Oli.vert »
I use the 5L Exped drybag that my PJs live in (merino baselayers and warm socks).
Remove contents, refill with folded wool cycling tops, close to include some air. Slide the bag into a buff.
It ends up about travel pillow sized, but traps heat, gives soft support without being bouncy, and isn't claggy against the skin.
A nice touch is in re-purposing something I'm carrying anyway.
TheBrownDog
Post by TheBrownDog »
Ben have a look at the Eagle Creek Fast Inflate jobbie. It's huge, weighs not much and packs down very small. Ive had mine for two years and think it's the dog's. Not cheap mind.
https://www.amazon.co.uk/Eagle-Creek-In ... ay&sr=8-11
Bought the trekology one, really cheap. Seems good on a quick test of the sofa. Will test it properly on the next bank holiday weekend
So I spent two nights at cub camp using the trekology pillow (on the slopiest pitched tent ever, they were left up for us to use as they were still wet from the school who were there before us)
Pillow was comfier than my exped one. Came with a strap that let me secure it around me mat which was a big bonus. Valve is slightly over designed but overall I'm impressed
yeha
Post by yeha »
Just found this and had to share...
https://eu.ostrichpillow.com/products/o ... w-original
Only those who will risk going too far can possibly find out how far one can go - T.S.Eliot.
How is that 70 odd quid :shock: I've just tried putting one of these on my head, seemed to work fine and was only twenty quid.
composite
Post by composite »
For those solo nights out in the wild.
