Help! Testing Dynamo output
HUX
Post by HUX »
Guys how do I check my dynamo output. I have a new Love Mud Juice boost hub 6v 3W and whilst it does power my light it's not as bright as I expected and my phone won't charge off my sinewave revolution even though it says it's charging. They are switched so run independently. When I stick the volt meter on the cable from the hub and the hub itself it fluctuates between 0 and 0.8v. Any ideas? it doesn't seem right to me.
Checked the meter on a AA
Heath Robinson testing contraption
Re: Help! Testing Dynamo output
Dynamos/generators are AC not DC!
The useful output is the DC side of the converter and for that I use a Muker in-line USB meter https://www.amazon.co.uk/MUKER-V21-Mult ... 01BUQ5I3G/
Massive round of applause for the test bicycle
pistonbroke
Post by pistonbroke »
Be careful not to run the wheel backwards as this will cause an interruption in the space time continuum and a black hole to form. (Warning this may be bollocks) I'd probably have mounted the wheel against my bench grinder wheel to give a constant speed but this almost certainly wouldn't have ended well. Good job you're not a member of any of the emergency services which tend to frown on messing about with electricity :geek:
mat_swan
Post by mat_swan »
Be careful not to run the wheel backwards as this will...
...condense static electricity out of the air to cope with the dynamo contacts in negative polarity. Spin it backwards fast enough and you'd best watch out for lightning.
I would also like to applaud the test setup
larsmars
Post by larsmars »
HUX wrote:Guys how do I check my dynamo output. I have a new Love Mud Juice boost hub 6v 3W and whilst it does power my light it's not as bright as I expected and my phone won't charge off my sinewave revolution even though it says it's charging. They are switched so run independently. When I stick the volt meter on the cable from the hub and the hub itself it fluctuates between 0 and 0.8v. Any ideas? it doesn't seem right to me.
I can’t quite see what you are doing there. You won’t be able to to get max power even with your Rube Goldberg machine. Try riding 25k/hr for a few minutes. You will be surprised how much speed is required to sustain a decent recharge with the Sinewave. Unless you are riding roads you will be on trickle charge and dims lights, especially if you are expecting to run lights and Sinewave concurrently.
Hux, as Bob says, set the voltmeter to AC. You should be getting 6v with a load across the output (have you got a Revo or similar) and without a load across the output you might get up to 30v .
And yes, top marks for the test bicycle!
Have you used the light with another hub and thought that it was brighter before?
When I first got my Revo I didn't think it seemed bright enough. It's meant to be 800 lumens but it didn't seem as bright as my 400 lumen head light. But having looked into it the Revo beam is wider so the lumens are spread out over a bigger area so the centre is less spotty if that makes sense.
As for charging devices, I've no personal experience of it but when I was researching it that it seems you need to ride quite quickly for a long time to charge anything up. Better for road tours or charging devices with low power demands, so not modern smartphones :smile:
lune ranger
Post by lune ranger »
My experience of the Juice Vs a SON is that it has poor output. As you experience I got poor lighting at night and next to no charging by day.
I had other problems with the Juice and eventually got a refund and moved over to a SON. On the recent BB200 in the 10hrs of daylight on Saturday I charged an iPhone 5. It only dropped from 100% to 40% with an average overall speed of around 8.5kmh. At night the Revo was ok but no where near bright enough when riding on slow off road climbs or on HaB.
On my road setup riding keeps my iPhone at 100% charge and lighting with an Edelux 2 is fine at all times.
I charge using an Igaro and have a switch to select either charging or lighting.
HUX
Post by HUX »
Thanks all. I've bought 1 of those gadgets for a fiver to check the output of the sinewave. It does look like you need a decent constant speed to get any charge so not ideal for off road. The light is adequate but is a very wide beam pattern with no real spot. I guess I'll just experiment and see what it's capable of. Maybe I was expecting too much from it as it's advertised as plug and play!
I think we've been spoilt by high output battery lights that make riding at night as light as the day time. I'm used to the revo now but I also have a joystick on my helmet for technical bits but most of the time the revo is plenty enough to see where I'm going.
I'd also say that dynamo lights seem a little dim when coming from modern battery stuff and the problem is worse at low speeds. I've found the Revo to be poorer at low speed than the K-lites, I put this down to the Revo having a larger capacitor ... but I could be wrong.
rufus748
Post by rufus748 »
I spoke to Kerry before buying the klite when I was having problems with my revo (being too dim at low speeds)
I recall he designed both and only wanted 3 'bulbs' in the Revo, exposure insisted in 4 which it doesn't have the power to property supply at low speeds.
He described the Revo as a road light which is why he went on to build his own
larsmars
Post by larsmars »
rufus748 wrote:I spoke to Kerry before buying the klite when I was having problems with my revo (being too dim at low speeds)
I don't think Kerry designed the Revo. My understanding is that was inspired by a design called the Deanamo by Rob Dean.
I've got both a updated kLite and the Revo. The kLite is brighter at lower speeds and is a damn good light, but the standlight on the Revo lasts much longer at low intensity. Unfortunately, I find the kLite is a bit more cumbersome with the external standlight pack and switches and wires. They are both great lights in my opinion.
Which are the reasons why I've always assumed the Revo has a larger capacitor.
rufus748
Post by rufus748 »
larsmars wrote:I don't think Kerry designed the Revo. My understanding is that was inspired by a design called the Deanamo by Rob Dean
Ah, I don't know about that. Came from the horses mouth. Could have been an over enthusiastic sales pitch, but it worked.
HUX
Post by HUX »
I read something this morning written by Kerry saying that he spent ages developing the K Lite only for it to be copied by Exposure and when the Revo came out everyone wanted 1 because they'd never heard of k-lite despite it being better. The power of marketing was mentioned! Needless to say he was properly pissed off.
Back to my issues. Tested the sinewave and it is kicking out 5v but cannot get an amp reading. Connected it up to a 12v battery and tried to charge my old samsung.managed 7%in half an hour. Not great.Put it back on the bike and within half an hour of riding phone was up by 25%. Great. Plugged in new samsung for an hour and nothing 0%. Back to the old phone for half an hour of riding and nothing 0% improvement. 20 min back home and it was up by 20%. So it does work...when it feels like it. Doesn't like my new phone though ~X(
It might be the lead,will do dome more experimenting :???:
larsmars
Post by larsmars »
HUX wrote:I read something this morning written by Kerry saying that he spent ages developing the K Lite only for it to be copied by Exposure and when the Revo came out everyone wanted 1 because they'd never heard of k-lite despite it being better. The power of marketing was mentioned! Needless to say he was properly pissed off
That’s pretty much how I remember hearing/reading it.
Sorry to hear of the issues with the Samsung phone. Have you tried charging a USB cache battery instead? I’ve resorted to that for my Sinewave because I found the constant speed changes resulted in unreliable charging of my garmin and phone.
Mart
Post by Mart »
Some mention here http://robdeanhove.blogspot.com/2011/12 ... go-go.html
