Is this bike any good for bikepacking?
bikeandbivvy
Post by bikeandbivvy »
So I can't afford a Surly etc and have limited cash and don't think i'll get a great bike secondhand for £300 so another option is to look at topping up my cash with my cycle to work scheme . I looked at an extra £300 (I don't like to over commit!) and for that (well actually £585) I can get this Trek X-Caliber 7
https://www.trekbikes.com/gb/en_GB/bike ... 7/p/21576/
Seems to have good frame, ok fork and basic groupset (I didn't want 1x11). Frame design is good for bags etc I figured but you guys/gals all have far more experience than I! Sensible purchase for the money? Waste of time? Any advice welcome
Re: Is this bike any good for bikepacking?
its ok but you will get more bang for your bucks with second hand
personally i dont like coil forks and especially so for bikepacking [ i put more air pressure in when i am loaded up and spring lacks the tuneability] though most use a rigid fork.
IMHO pretty much any bike will do for bikepacking though I tend to avoid carbon and prefer steel
YMMV
bikeandbivvy
Thanks Lazarus I was seeing what was available for £300 cash v £300 cash+£300 cycle to work and the latter seemed to offer more plus its all new parts & warranty etc where as I could end up spend more on wear and tear sooner on a second hand bike.
Air sprung forks would be better but not within budget on new that I can find! Think given budget I'm a bit limited. Not even got my bike bags yet just got a rucksack tarp & bivvy!
At least coil sprung forks won't blow seals and leave you with bottomed out forks... and cranking up the preload a bit will accommodate a heavy front bag
As above any bike will go bikepacking that one would be ideal
Moder-dye
Post by Moder-dye »
htrider wrote:At least coil sprung forks won't blow seals and leave you with bottomed out forks... and cranking up the preload a bit will accommodate a heavy front bag
Other than mine which had the spring blow out the top near white bridge. Rockshox XC32 IRC
Had a more aero ride back to Aberdeen :-bd
