LARGE CLEAROUT (New stuff & price drop)
Need to clear the spares out. Prices exclude postage at cost (£2-£4). Either PM me or mail on ahwrigley@gmail.com (best way as dont often see messages).
Pictures here: https://flic.kr/s/aHsm8YsXyS
Shimano FC6603 Ultegra 10/11 speed triple chainset. 175mm arms. 30/39/52 t rings in good condition overall. Bit of rub to DS crank arm. £45
Titanium Bash guard for 104bcd cranks 140mm diameter for 32t ring. 2mm thick £18
Tektro RL720R Cross top levers for drop handlebars. 31.8mm clamp. Black £8
Hope Matchmakers HBSB 248. Pair, for attaching M770 shifters to X2 Evo brake levers. £8
Chainrings:
SLX 104bcd 42t alloy chainring. Very light use £5
Uberbike rear cassette 42t expander sprocket. Gold, used but will still take new chain £5
Shimano XT 22t 64bcd granny ring. Brand new £6
Shimano 76bcd (for road triple) 30t chainring £5
DT Swiss 350 Rear hub. 142 x 12 bolt through. Shimano ratchet freehub. New £90
Single Shimano BR-505 mechanical disk calliper. Silver. Good condition £8
Quick releases
Salsa 170mm QR spindle for 170mm fatbike rear wheel. Silver, excellent. £15.
Hope (old style) 135 rear QR (or Fatbike front), Silver, Scuffed.
Free with something else
Race face fat bike bottom bracket 100mm centre tubes
Deore 36t 104bcd Chainring for double 10 speed. Wellused but should take new chain
sold
Easton Monkeylite Carbon hi-rise bars 31.8 clamp 685mm wide 40mm high. Scratches where clamps fitted (not by me) so good for pub bike £8
Shimano RT86 Icetech 6 bolt rotors 160mm & 180mm with bolts and lock washers. V light use £22
Shimano M8000 rear derailleur. 11 speed, medium cage (can also use on 10 speed wide range). Bought as spare. Brand new, never used. No box so cant send back £40
Hope Pro2 front hub, non boost can do 15 or QR adaptors £30 (will have rear for sale when have replaced bearings).
Pair V Rubber Rail 29 x 1.75 (47mm) fast rolling gravel/29er tyres. New £20.
Works Component 104bcd 30t narrow wide chainring. New. £15
Pair deore steel stamped 104bcd 32t ramped chainring. One new, other used once. £3 each
Superstar components 104bcd 32t narrow wide, grey. Used once £10
Shimano XT M770-10 10 speed right rear shifter. Single release. Comes with free working fine rear shifter thats missing its handlebar clamp. Works fine £10.
Thomson Elite 27.2 x 410 black Layback. Couple light scratches starting at 200mm from rail. £24
Hope (old style) 100mm front QR, black, scuffed, £4
2 x Salsa Anything HD Cages and 2 x Anything Drybags. Good overall condition with some light signs of use. Bought off here recently but not now needed as selling Fargo. £60
Shimano 105 5700 11 - 28 10 speed cassette. Largest 3 sprockets on alu carrier. Remaining sprockets loose with spacers. Comes with alloy XT lockring. Used once before swapped to 11 - 32 so near perfect.
SDG Bel Air RL saddle in brown with Titanium rails. Good condition
Shimano XT 135 rear QR, some scratches, black
Shimano XT M780 10 speed right, rear shifter. Multi release. Can provide with bar clamp or I-spec A or B adaptor.
Shimano XT M770 3 x 9 Outer ring 44t
SRAM 135 rear QR, black, vgc,
Salsa Flip Lock QR seat clamp 32mm Silver. New. £12
Tune Strangler 34.9 seat clamp with Titanium lever 28gms! Couple light scuffs £18
Campagnolo down tube cable adjusters, new £5
Shimano 105 FC-5603 Triple cranks. 172.5mm arms. Was going to make a Sub Compact double with these using the 76 bcd inner and 130bcd middle. £15
Sunrace 9 speed thumbshifters. Bought off Stuart of this parish. Not now going to use. Have added Ritchey inline cable adjusters which fit direct to shifter. £30
Shimano XT M770 3 x 9 middle ring 32t VGC £10
Chainrings:
Quick releases
sold
Re: LARGE CLEAROUT
could I get a few pics of the mokeylite carbon bars please? maxwell.isnt(a)gmail.com
ta
ta
Re: LARGE CLEAROUT
What colour is the Hope front hub? I'd be interested in the rear as well. No need to replace the bearings, I'm a master at that
I have a stock of bearings and the Hope tools.
Re: LARGE CLEAROUT
Fudge: Will do
Bobcatmax: Someone beat you to it via email, if dont take will let you know
Sean front hub is black. Rear is black non Evo. Currently with 135 x 10 axle, but have a 135 QR axle was going to fit when change bearings. Please email if either work
- gordonbennett
Re: LARGE CLEAROUT
Interested in the Shimano M8000 rear derailleur.
Also what colour is the Salsa flip lock?
Re: LARGE CLEAROUT
Interested in the seatpost if it's not snapped up.
Re: LARGE CLEAROUT
Seatpost still available. Please email me (address at top)
Re: LARGE CLEAROUT
If you'll split the Anything Cages and bags I'll take the bags.
Re: LARGE CLEAROUT
Just measured and theres 25cm of seatpost exposed on my bike, so I'll leave it thankswriggles wrote:Seatpost still available. Please email me (address at top)
Re: LARGE CLEAROUT
Shimano XT M780 10 speed right, rear shifter please. I'll pm later on. Cheers
Re: LARGE CLEAROUT
cool, yours, no rushDrliamski wrote:Shimano XT M780 10 speed right, rear shifter please. I'll pm later on. Cheers
Re: LARGE CLEAROUT (New stuff & price drop)
Updated with new stuff and prices dropped
- Brothersmith
Is this still up for grabs? If so can I take it with bar clamp pleasewriggles wrote:Shimano XT M780 10 speed right, rear shifter. Multi release. Can provide with bar clamp or I-spec A or B adaptor. Vgc £16
Sorry it sold yesterdayBrothersmith wrote:Is this still up for grabs? If so can I take it with bar clamp pleasewriggles wrote:Shimano XT M780 10 speed right, rear shifter. Multi release. Can provide with bar clamp or I-spec A or B adaptor. Vgc £16
Sunrace 9 speed thumbshifters (pair of 3x9's?) still available?
cheers
cheers
Hi Tom yes they are - cheers Andy
Hi Tom - please check your private messages - thanks Andy
