BARS...
Ritchey Trail WCS riser, 31.8 x 740 mm wide, 20mm rise, 9d sweep. Well used, on a couple of long trips last year, so has wear marks and a couple of dings at the end. £15 plus postage
Ritchey Trail 2X flat, 31.8 x 720 mm wide, 5mm rise, 9d sweep. Came on my Jamis Dragonslayer 2016 but I never really get on with flat bars. Probably used once or twice before I swopped it out, so unmarked. £20 plus postage
Genesis RandoX Flared drop. They say they are 440 mm wide - this is probably centre to centre at the front of the drops. At the end of the drops, they're 470 mm wide centre to centre. D125 x R70mm. Came on my Genesis Croix de Fer 30 but swopped out for something with a wider flare. Quite a flat top, with a rear bend. Unmarked. £20 plus postage
SADDLES...
WTB Volt Comp. It doesn't say anywhere but measured its 135 mm at its widest, so is the narrow version. Lightly used (i.e. I can see some dried mud on the bottom and some marks on the rails, but other than that its unmarked. £15 plus postage
Specialized Henge Comp, 143mm, virtually unused, and totally unmarked. Bought a couple of years ago to find that elusive fit but it wasn't right so its been in my box of stuff ever since. £35 plus postage.
Genesis CX, cr-mo rails, virtually unused, unmarked. £10 plus postage
