Invermoriston to Skye
Anyone know of any interesting trails/cycle paths to Skye from Invermoriston? Had a looks at sustrans etc but can't find much.
Re: Invermoriston to Skye
Depends on how technical, etc you want but the reverse of the HT550 route: Invermoriston-Tomich-Glen Affric-Morvich-Dornie would get you most of the way there. Apart from the descent to Glen Licht it's straightforward. Worth checking http://www.heritagepaths.co.uk/mapsearch.php as well.
In days gone by I've done it this way too, Bob. Just as much pushing as the HT direction, except you're mainly pushing downhill!Apart from the descent to Glen Licht it's straightforward.
In any case Camban to the Licht hut is *only* 2 hours.
Have you done the trail to the north of Ben Fhada via Bealach an Sgairne? I've read that it's a better descent.padonbike wrote:In days gone by I've done it this way too, Bob. Just as much pushing as the HT direction, except you're mainly pushing downhill!Apart from the descent to Glen Licht it's straightforward.![]()
No, thought about it but always gone the Camban way, even in my pre-HT days.
I have done the cut over from Morvich - Strath Croe - then due north through the woods and Inverinate Forest to then drop on the track and head west to Iron Lodge - 4 difficult and unrideable kilometres!
Sorry should have said I'm using a gravel type bike so nothing to technical. without pushing would be good
I'm sure Colin aka Scot routes took a gravel bike down Glen Lichd on the basis that it wouldn't be any more pushing than on a mountainbike and is only for a short distance in relation to the overall length of gravel road throught he Glen.
That said I reckon it is all rideable downhill but that might just be my inner teenager.....
You should be OK apart from the Glen Lichd descent which is about 2Km. There'll be the odd step here and there that you'll want to get off and carry but there's not a lot of those.robbie wrote:Sorry should have said I'm using a gravel type bike so nothing to technical. without pushing would be good
Here's Colin's Glen Affric report - http://www.blog.scotroutes.com/2016/06/act-2-ride.html
I took the + bike for the Affric-Kintail Way Phil. As you say, there's a balance to be had between the faster bits (Drumnadrochit to Strawberry Cottage), the rough track from there to Camban, the techy descent down to Glen Lichd and then the easy track out to the main road.htrider wrote:I'm sure Colin aka Scot routes took a gravel bike down Glen Lichd on the basis that it wouldn't be any more pushing than on a mountainbike and is only for a short distance in relation to the overall length of gravel road throught he Glen.
Edited for emphasis: The roughness of the track between Strawberry Cottage and Camban shouldn't be underestimated.
Other options would include heading from Alltbeithe down to the Cluanie Inn (horrid) and then the A87 to the foot of Glen Sheil, then the Mam Ratagan to Glenuig - or from Invermoriston down the GGW to Invergarry, forest track to Tomdoun, the road to Kinlochourn and then the muddy track through to Glenuig. Both of the latter assume it's between Easter and October and the wee ferry is running.
I have, it's the best descent I've done in the UK and right up there with the best anywhere.Have you done the trail to the north of Ben Fhada via Bealach an Sgairne? I've read that it's a better descent.
