Does anyone have a GPX for this?
Technically I only need the lower half to get from near Cambridge to Ivinghoe beacon.
Icknield Way
Re: Icknield Way
For anyone else, the GPX is here -> https://mtb.waymarkedtrails.org/#?map=1 ... 49!-0.4164
Just click the 'routes' button in the bottom right hand corner and then select Icknield Way, then you get an option to download the GPX.
Took me bloody ages to work that out!
Re: Icknield Way
It seems to add about 300k of squiggles when i try opening it ion ridewithgps or similar....anyone have a "clean" copy?ctznsmith wrote:For anyone else, the GPX is here -> https://mtb.waymarkedtrails.org/#?map=1 ... 49!-0.4164
Re: Icknield Way
Yes. Went in and manually got rid of the squiggles (and then forgot about them). Will share from ridewithgps later.
